The little prodigy is now very mobile and SWMBO declared that she needed a step stool to make life easier for her.
I fully agreed, but didn't want to make this a huge exercise, so started scouring the Internet for plans for a cheap and cheerful stool. Of course I found quite a selection, but as I don't have a lot of wood in the garage at the moment I needed something that was frugal in terms of materials.
After a while I came across a plan that required only 4 foot of 8" x 3/4". Surely I've got that sort of wood lying about. Off to the garage to rummage through the piles of offcuts, and sure enough, nothing that comes even close to 4 foot of anything.
Hmmmm. Time to get creative. Having done some laminating in the past (see Office Desk Project) I thought I could use up a whole bunch of left overs to create the appropriate 8" x 3/4" lengths. How hard can it be?
I set the table saw up to rip at 3/4" and started madly feeding all the 12" offcuts I had lying about past the blade. After what seemed like a lot of cuts and a huge number of scrap pieces I thought I must be getting close. I stopped and checked the combined width of the new laminate pieces. Half way. WHAT!?!? Hmmmm - this is going to take a lot more scrap pieces that I thought. Scrounged every last piece of usable scrap I had, and quite a few previously classified unusable pieces. Eventually I had enough.
I left it at that for a while, came back when I had the nerve and glued up the laminated boards. I've learned to close my eyes at this stage, because it always look very rough. Then I pulled out the belt sander and went to town. Ahhh - that's better.
Good - now I have my sized pieces to work with. This has already become a multi-weekend project, when it was meant to be a couple hours. Not going to plan so far.
I cut the pieces to spec, puzzled over how to cut out the semi-circular sections in the size panels, created a jig/template for the router to achieve this, and was about to apply the screws to it (literally), when SWMBO came out to see where I was up to.
"Oooooh - that's pretty." (*Pleased*)
"It'd be a shame to mess it up with screw heads." (*Uh-Oh*)
"You always do such nice work." (*Ego stroked*)
"Can't you figure out a way to assemble it without the screws showing." (*Darn!*)
So I left it sitting, in pieces (there's only 4 pieces, but even so...), on the bench while I mulled over a solution for a couple of weeks. 2-3 hour project? Nope, that's not the way I do things. I HAVE to complicate them into multi-month enterprises.
Finally decided that if I routed hidden/stopped dados in the top and sides, the center brace should be able to hold it all together with just glue. Hmmmm. Again, it took a while to get my courage up because I've never done dados before, but eventually I got sick of seeing the pieces glaring at me every time I parked the car so one evening I fired up the router and went at it. Apart from a slight overcut mishap, which I patched with a scrap piece, it all went to plan.
Some minor touch up with a chisel, a generous application of glue, sanding, stain and three coats of semi-gloss polyurethane later, the job is done.
For being left over scraps of wood that looked more like paint stirrers than usable lumber, I am thrilled with the final result. Is it strong enough without mechanical fasteners? Well, I'm rating it at 200 lbs. How do I know. I stood on it and it didn't collapse so it should be able to hold a 16 month old!
Total cost of project. $0.00, not counting labour hours, of course.
Enough of all that, here are some photos.
Cheers,
John
Cheers,
John
