You could always drill thru, at each end of the cut, then use a sabre saw.
I did not mention, but the ends of each handhold will be drilled out to 1 3/8" prior to the saw cuts, using a forstner bit. A portion of the saw cuts (at the top) may break into the drilled out holes. I am planning on finishing the cuts with a crosscut hand saw (which I'm also having sharpened).You could always drill thru, at each end of the cut, then use a sabre saw.
My first thought was a jig saw.set the saw on the 2xw/ the blade fully retracted..
loosen the depth lock ...
start the saw...
now plunge while keeping the saw's plate/shoe in full contact w/ the 2x..
better yet...
be safer an get yourself a jigsaw....
Yes yes yes. Using a C-saw on this scares the crapoutame. I'd hog out the waste with a forstner and if the router bit isn't long enough, clean from the other side with a flush trim bit.Plunging the circular saw is just a question of practice to become confident, don't forget to try a scrap piece first. That being said a router would do the entire job perfectly with a similar jig, start with a drilled through hole if you do not have a plunge router. Depending on router you would probably want to cut 1/2'' deep with each pass.
Rob
sure would be easier less goof proof...My first thought was a jig saw.
