I've been working on my RT cabinet for several months now and needed to cut a 6" hole in the side of some 3/4" maple veneer plywood to connect my DC hose.
The Jasper 400 replaces the router base plate and cuts 1" to 7" in diameter in 1/16" increments. It comes pre-drilled for many routers (compatibility guide attached) and a centering jig. All told, it was installed in a couple of minutes.
It pivots on a 1/16" steel pin (provided), so usage simply entailed tacking a scap piece across the back to retain the cutout, drilling the center hole, inserting the pin and placing the jig hole corresponding to the diameter you want to cut and pivoting the router. In my case I cut the hole on a vertically mounted panel. I've attached a few pictures of the jig mounted on my Craftsman 17543 plunger, the piece cut out and the finished hole.
As you can see, the resulting cuts was very smooth. It is sized for use with a 1/4" bit, in order to permit 1" diameter holes. At $20 on Amazon for a jig with 97 precision-cut holes (1" to 7" by 16ths), its tough to justify making your own, IMNSHO.
Great buy!
Great buy!
