I know, another not quite finished project yet again....This one is something I've needed for a good while or at least I tell myself that. The mobile clamp cart is a great idea but I caution of several things, 1st it can get very heavy very quickly especially with parallel clamps, and 2nd it can tip if not careful as I found out when first loading clamps. If you look closely you'll see an 80# bag of Sakrete in the base on the cabinet side bottom left corner. It isn't there for storage......I also later added the two boxes of 24" sliders and on of 14" because they too are heavy and in need of a place to be. But they ensure stability so no tipping happens and that's a good thing. The plans were followed mostly. As with most plans I usually alter to fit my needs/desires. The overall cart is the same with exception to the 3 drawers where the plan called for only on with adjustable shelves. I drilled for that but decided later the drawers made more sense to me. The top left drawer holds my bulk most used wood screws while the yellow Stanley compartmental case holds the separated bins of screws. The individual bins are removable from the case which allows me to bring its bin over to the project. The top holds the glues. The second drawer down holds the Kreg cabinet jigs (shelf pin jig, cabinet hardware jig, and cabinet hinge jig) as well as a pair of Bessey corner clamps. The single right side drawer holds the drawer slide jigs (a Rockler and Kreg) as well as the Kreg self adjusting clamps with a second pair of Bessey corner clamps.
The unfinished part of course are the drawer fronts and pulls. Maybe later next week as I have an astronomy conference this weekend and I'm too tired from tending to a smoker session from yesterday. Yes, after almost 15 years I' smoking again! And happy to be so....but now it's pork butt, baby back ribs, chicken, and hopefully soon my first brisket. No I'll never go back to cigarettes. That was the hardest thing I've ever quit and I have no desire to ever go through that ordel again. I'll probably gain weight from this too.....
I do stress that anyone building a cart like this be very careful of first loading it with heavy clamps and check along the way for stability. It did indeed tip while I was loading it and thankfully no one was hurt. These clamps get very heavy very fast. Loading a good base counter weight should be the first consideration IMO. Anyway pics posted below and I'll follow up when the drawer fronts are made and installed.
And for those having problems orientating their posted pictures, when you rotate the picture in your image software as you want posted save it as such and then upload. I think that will preserve the orientation. If you close the picture after saving and then open again it should be as wanted. Just a thought.
