1 - 6 of 6 Posts
· Registered
Hi everyone, this is my first time using this CNC Machine. The purpose of buying this machine is that i wanted to mill my own PCB using the CNC3018 Pro. But i am having this problem for a few days and i have been searching online but with no result. The problem I encounter is that whenever i try to do the z-probe or the heightmap for my PCB, I will always get and alarm status on my candle GRBL software, and in the console it doesn't mention what is the error. So my question is :
1) Is there anything i need to do before i started doing the heightmap? ( I have already connected the crocodile clip to the A5 pin of the controller board and also when doing the heightmap, i have connected the crocodile clip with the engraving bit and my copper clad)
2) Do I have to set up the homing position before i started doing the heightmap?
3) I really think that i have miss some important step for doing the hrightmap ( I am new to this CNC world)
Extra Info:
1) The result from the $$ command
$1=0 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=1 (dir port invert mask:00000001)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.010 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=400.000 (x, step/mm)
$101=400.000 (y, step/mm)
$102=400.000 (z, step/mm)
$110=1500.000 (x max rate, mm/min)
$111=1500.000 (y max rate, mm/min)
$112=1500.000 (z max rate, mm/min)
$120=10.000 (x accel, mm/sec^2)
$121=10.000 (y accel, mm/sec^2)
$122=10.000 (z accel, mm/sec^2)
$130=320.000 (x max travel, mm)
$131=195.000 (y max travel, mm)
$132=45.000 (z max travel, mm)
2) I dont know what to provide anymore, if u need anything just let me know and i will try to provide it.
Thanks for anyone who are willing to help this newbie solving this issue. Much appriciated.
· Super Moderator
John
Hello and welcome to the router forum, Jack
Sorry I am unable help but we have a lot member that use CNC’s that can
· Official Greeter
G'day, ksdan, welcome to the forum.
1 - 6 of 6 Posts
