Welcome to the forum, @Curtis Mateja ...
I am not sure how to do so, or what all that entails.Welcome to the forum, Curtis! Have you calibrated the machine?
I can’t say no for sure. But I double checked all my designs and they are all in inches. Unless the post processor is converting it to mm. If that is the case I have to do some digging to see how to correct thatIt actually sounds like it was designed in mm and you are using an inch postprocessor. 25.4 mm is changed to 25.4 inches. Does that sound like what is happening?
But if it was converting to mm, it would be smaller correct?I can’t say no for sure. But I double checked all my designs and they are all in inches. Unless the post processor is converting it to mm. If that is the case I have to do some digging to see how to correct that
Awesome! Thank you sir, I will check it out and let you know what I find out.Yes if the project is designed in inches then you use a mm post-processor then everything will be very small when cut. That is why I questioned if it was designed in mm then an inch post-processor was used.
If you are designing in inches and you are using an inch post-processor then I would say the settings are off. As David said it needs to be calibrated. Here are two links to videos that will explain what you are needing to do, but they are Mach 3 based. I'm not sure what these would relate to with your machine but I think you need to calibrate your machine.
