cnc control box
2382 Views 6 Replies 6 Participants Last post by  maddog
does anybody know of someone
who reliable control boxex for xyz for Chinese cnc tables?
1 - 7 of 7 Posts
So, I'm assuming you have a Chinese machine and the controller is not working properly. Maybe you could start with clearly telling us what isn't working. Old machine with broken control electronics or a new one that isn't working properly? There is a huge range of possibilities and I'd be hesitant to suggest a direction without knowing what problem you are trying to solve. A few photos would probably help as well.
Reactions: 2
I just want a new one not Chinese, simple xyz
when my cutters jam is spikes the box then thepowerblows and the box is useless
I have a quality one box now that works perfect
but I have the spindle seperatly operated so the box is seperat from spindle
so im half way there
I baught a inverter getting that wired by electrician this week
I have 2 cnc the other one I would like to try a new control box does any body know of anybody that has turnkey boxes for xyz control box
will do sindle seperatly
on eBay, there is "CorvetteGuy50". He is heavily into CNC and the various motors, controllers, etc. He has a good reputation.
A control box needs to be designed to match the steppers/servos that are used on your machine. If you have a little 1610 CNC or a large 4’x8’ machine with 1.5kw servos, they will require different control / drive systems, so the more info you can provide, the better of recommendations can be made.
If this is a newly purchased machine, I would recommend contacting the seller to provide you with setup and operating instructions.
Don’t know if this helps. You don’t have to purchase the steppers . They have them prebuilt for Nema34 and 23
Plug and Play NEMA 34 CNC Control System - CRP800-00E-8 | Avid CNC | CNC Router Parts
1 - 7 of 7 Posts
