Cnc Newb, Looking for advice on cutting polycarbonate
1 reading
1.7K views 9 replies 6 participants last post by  UglySign
Hello,
I'just just aquired a cnc router table from a family member and have the oportunity to make some templates for a local company.
i've attach a drawing of said template that they want cut out of 1/4" polycarbonate.
My problem is figuring out best way to cut the 1/8" slots, and they want a small chamfer on the slot as well.
I guess what i'm looking for is for someone to point me in the right direction as far what router bits to select to get this done.
Any help would be greatly appreciated.
Thanks.
G’day and welcome to the forum.
Reactions: ShedShop
#4 · (Edited by Moderator)
I actually did something recently like this.
Same 1/4" (.22") thickness and same size slots
Make sure you do the slots first & w/ a 3/32" bit or piggly wigglies happen
A straight open line cut can take on the bevel/chamfer, just set the proper depth
Also helps to screw in scrap to hold down the Poly from moving when its time to cut out.
Polycarb (PC) can &/or will lift if not fastened down good. Chips like to go under.
I onion skinned down to .19" w/ a 1/4" bit then cut out w/ a 3/32".
Plan a 'what if I' strategy to foresee what could go wrong.
Things will change as you get a feel for cutting PC more & more
Test cut on scrap before you dive in.
I don't like PC, to me it will always be nasty
* The bottom slot looks off center, that side is narrower and could cause problems.
Use Bridges or as they call them tabs to help hold.
Ramp in all cuts. Climb cut
In a nutshell... others to follow
New sharp carbide bits are a must. Polycarbonate needs new sharp bits. Speed about 15,000 rpm any faster you can create problems. Use old bits on some 1/4 inch hard board. Helpful to correct flaws in the coding. Adjust and repeat till you achieve the results your looking for, then apply that to the project piece. Hope that helps.
I have worked with PC quite a bit here lately and I do like it, the current bits I am using are are Single Flute Endmill and Two-Flute Low Helix in various sizes. Through a good deal of trial and error I found these to be the best suited for finished products, from a relief carvings to a full sized job box. The main thing I learned is to be mindful of the heat being generated and that the material is very unforgiving, you mess something up it is near impossible to fix it. So planning is key to successful finished products. Fortunately I found a seller on Ebay that I can get 1/2" PC from super cheap so it allowed be to experiment and learn a good deal. I am sure that a lot of folks would disagree with me but I have been very satisfied with my end results. Polycarbonate Sheets Panels | eBay
