It's been a while since I've checked in here... hoping someone has an idea here. I have a Probotix machine. I've had this issue a few times before, and every time it happens, I've had trouble resolving it. The issue is that corners that should be square, end up getting a radius if they are not at the start/stop point.
All of my modeling is done in Fusion 360. The toolpath simulation in Fusion creates the correct result. However, when I run the program on my machine, the actual toolpath shortcuts around the corners creating a radius, where there should be a sharp 90* angle. The preview of the toolpath on the Probotix/LinuxCNC shows the correct path, but when I run it, the actual path has these errors at sharp corners. You can see it on the screen as it cuts, where the actual toolpath, displayed in red, does not follow the loaded toolpath, which is previewed in white.
I will get some pics uploaded to show what I'm talking about, both on the monitor of the machine, as well as on the parts I'm cutting.
Brian
Brian
