Looks great! What were your feeds/speeds for this? Did you try a V-bit?
Hey CharlitoHello, thanks for the greeting. Does anyone know if a CNC router can engrave the aluminum business card blanks, or are they more intended for laser engraving? I saw some that are 0.8 mm thick and it seems possible to engrave 0.5 mm deep and be ok, but then clamping it may be a challenge...
you would have to provide a lot more information on this product: as well as a photo of the product actually used.Have you ever tried windshield defrost spray instead of oil when cutting aluminum?
Hey 47chevy... you can try Muntz 280 - at the same token we basically engrave in ⅛" ~ ¼" material, so I can't say for thin stuff.I thought 360 alloy brass was referred to as engraving brass but I can not find anyone to supply 360. 260 is easily found. Does anyone have experience using 260 brass ? Does anyone know of a supplier of 360 brass !2' X 12" X .03" ?
