CNC Router to Suit 75mm Deep Cuts in MDF
969 Views 3 Replies 4 Participants Last post by  ken in minnesota
Hi Routers',
I am wanting to purchase a CNC Router that can do the following:
  • drill up to 75mm deep, and
  • be able to use up to seven (7) sheets of 2400 x 1200 x 12 MDF, glue laminated together.
Any ideas?
I await responses
Kind Regards
1 - 4 of 4 Posts
There are dozens of machines capable of doing that. Our shop has a Biesse that cuts sheets all day. The biggest challenge, as I see it, is getting bits long enough to cut that deep. They are available, but pricey and prone to flexing.
You don't mention budget. Ours came in at something like $125K several years ago.
Reactions: 2
Welcome to the forum Doug.
if you just cut half way through than finished with a bearinged flush trim bit you could get by cheaper? dont know how many
or how often you would need that large capacity cnc.i have some projects i cut half through than band saw rest. clean up with
large flush trim bit, works great.
1 - 4 of 4 Posts
