if the bit is bottomed out in the shaft the waters will get muddied...
for tapping use wood, brass hammer or facing hammer...
no steel tools allowed...
Heat will often break the bond that is holding them...
A soldering iron works very very well for this...
more concentrated heat...
in the same vein you could go w/ cold... pack the bit/collet in ice for a while...
rotate the bit/collet while lightly tapping on the side of the collet...
Hold the router with the loosened collet nut resting on the workbench or the edge of a board and tap/rap the nut (not the bit and not the shaft) a couple of times.
still not working???
do the same to the collet on it's shoulder w/ the nut off...
