i know this topic has come up many times but non of the solutions that i've seen online have worked. I tightened the 1/4" Triton collet with a bit, not bottomed out. When i loosened the collett, i got to the part where it gets harder to loosen again just like every time, did another 1/4ish turn and the nut came off entirely leaving the collett jammed in the shaft. This was the first time i tried using the 1/4" collett as I normally use 1/2". Not sure if the nut was defective or if the collett just came separated somehow. I've tried tapping with hammer, heating with hairdryer then cooling collet with oil, tried using a hoseclamp to tighten the collett, etc. nothing has worked.
I've reached out to Triton and Toolstream and haven't heard back regarding suggestions or even a service center nearby. Does anybody have any other solutions that have worked on a Triton router
