6" rise = 12" extra length.
98 + 12 +110
111 is 1" too long.
98 + 12 +110
111 is 1" too long.
98 + 12 +110
111 is 1" too long.
My Grizzly 14" saw takes blades that are 105" long as well. I buy Timber Wolf blades and if you need help with blades they are more than happy to answer any question you might have.Mine takes a 105" blade, a 108 is too long.
https://www.amazon.com/Jet-708717-JRB-14-6-Inch-Riser/dp/B0000223N9
This kit is the same as the Grizly,Delta,Ridgid,Jet 14" riser.
We have a saw sharpening shop that will do it for $12.00.You could get them shortened. You'll have to check around your area to see who can do it. Lee Valley sells a splicing kit. Some of the outfits that sell blades might have that too.
The castings for these old style 14" band saws are all made in the same factory. The havn't changed from the 1940 Delta's.I have a Porter Cable 14" and I believe it's the same saw sold under many names... It's a 93-1/2" blade like Herb's. Are you sure your saw took a 98"?
Something on them has changed. Looking at Grizzly's website, the older 14" Band Saw, G1019Z, does indeed spec out to a 98" blade. Grizzly's current line of 14" Band Saws (G0555 line) uses a 93.5" blade. In either case, if adding a 6" riser to the band saw, you will need a blade that is 12" longer.The castings for these old style 14" band saws are all made in the same factory. The havn't changed from the 1940 Delta's.
My Mistake, you are right, @sunnybob was right you will need a 110" blade. The G1019 was 93 1/2" and the G1019Z model is 98" blade. You can get a blade off Amazon, Supercut blades are good blades, I use them all the time. They will even make them to length too.Something on them has changed. Looking at Grizzly's website, the older 14" Band Saw, G1019Z, does indeed spec out to a 98" blade. Grizzly's current line of 14" Band Saws (G0555 line) uses a 93.5" blade. In either case, if adding a 6" riser to the band saw, you will need a blade that is 12" longer.
I have not heard of Supercut blades. We live so far back inthe hills that the sun don't come up till about 1 PM. :wink:My Mistake, you are right, @sunnybob was right you will need a 110" blade. The G1019 was 93 1/2" and the G1019Z model is 98" blade. You can get a blade off Amazon, Supercut blades are good blades, I use them all the time. They will even make them to length too.
https://www.amazon.com/s/ref=nb_sb_...es&rh=n:228013,k:110"+supercut+bandsaw+blades
I use the 105" carbide impregnated blades, they seem to last longer.I have not heard of Supercut blades. We live so far back inthe hills that the sun don't come up till about 1 PM. :wink:
