hello everbody. I have owner a "cosmec cnc" . I can't load any program because space is full. i can't empty this folder.
I don't know the actual Machine. But sometimes it is not that simple.I am guessing "NC1101" is the computer running the CNC, and you are attempting to copy a GCode file from your desktop PC/Laptop to the CNC machine. The share is showing no space available. It is likely the permission of that share are not allowing write or viewing. You may need to check those permissions to get it going.
Are the controllers for these machines proprietary or parallel port based? If parallel port, it seems like it would be easy enough to add a MESA board (or at least once they get through the chip shortage) or a Smoothstepper where you could run these with more current PC hardware running LinuxCNC or Mach3/4. I know it is hard to move away from the older software, but the reality is the old hardware required to run these old OSes is starting to get to scarce.I don't know the actual Machine. But sometimes it is not that simple.
I once was asked to help a company connect a PC to their big old ATC CNC machine just bought second hand. The Machine was running DOS/window 3.1 and only a Win98 PC or a Windows XP (with Netbios) and a FAT16 shared folder with a specific name could allow the Machine to stream gcode commands.
Wasted my time as his Boss would not pay for a specially prepared FAT16 WinXP laptop.
So instead, I sold them a USB 1.44MB floppy drive for their Win 7x64 design PC so that they can transfer the gcode files (with comments deleted) into the m/c. Machine started milling beautiful 3D parts that way. Serial port streaming also would require a Win98 PC. That CNC Machine had small memory and a very small HDD.
