Hi everyone. I am new to this forum.
I just started trying to use a Craftsman model 315.17491 1-1/2hp router that I have had for many years but just never used until now. I bought a new Porter Cable tongue and groove bit to make some cabinet doors and mounted the router on a Craftsman router table. The bit makes 1/4" cuts that are about 1/2" deep so it is a pretty good sized bit. When I installed the t&g bit and turned the router on, there was so much vibration that the motor started rising on its own even though the clamping wing nut was tightened as much as I could get it, thus completely throwing it out of the depth adjustment. Nothing I did could prevent this from happening and I have been experimenting for hours so the router and bit are useless for my project.
I switched to a smaller rabbiting bit and did not get the vibration problem.
So the question is whether the bit is too large for this router and/or incompatible for whatever reason or is something wrong with the router or the bit. Is 1-1/2hp too small and weak to run such a bit smoothly?
I spent a good amount of time with the Porter Cable people discussing the out-of-balance possibility of the bit but no resolution was reached.
Any help will be appreciated.
