Craftsman dovetail jig
23825 Views 12 Replies 9 Participants Last post by  ju5225
Bought a Craftsman # 315.25791 because it had the 1/2 and 1/4 inch template. Did a nice job on the 1/2" but could not do a 1/4 because it calls for dovetail bit Catalog # 26319 for making the 1/4' dovetail. Unfortunately when I contact Sears they cannot find this bit and try to tell me any bit will work. NOT TRUE. :mad: I ordered a small bit from MLCS(3/8 width) but it is still to wide. The problem is it cuts the pins way to narrow. Does anyone know of a bit that will work?
1 - 13 of 13 Posts
Hi raporter
In order to cut 1/4" dovetails you need to use a 1/4" dovetail bit.
But the stock should not be thicker than 1/2 thick.
All the setting for the 1/2" will not work on a 1/4" dovetail and you will need to reset everything to cut the 1/4" dovetails.
1/4" dovetails are tricky to setup on most dovetail machines. :)
The deeper the bit the tighter the fit...loose the goose is the best fit for 1/4" ,they break so quickly :).
Take a look at the url below :)
C1510 1/4" 7° Dovetail Bit, 1/4" Shank
http://www.grizzly.com/products/c1510
http://www.grizzly.com/catalog/2006/Main/438
Bj :)
Just a NOTEs below
Sears Craftsman # 315.25791
315.25710 below ▼
http://cgi.ebay.com/Dovetail-Jig-an...ryZ20781QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Sears-Craftsman...ryZ50386QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Requires dovetail bit sears number 26318
Thanks BobJ3. I sent another inquiry to Sears and they tell me that bit is no longer available. I just ordered it last month so you would think they would discontinue the jig if they are not going to make a bit that will do the job. The reason I want the 1/4" dovetails is I saw some boxes made using them and they really looked nice.
As Bob has stated, you only need a 1/4" bit. You stated you ordered a bit but it's width is 3/8", either you ordered the wrong bit or, someone sent you the wrong bit. A 1/4" is a 1/4".
You're Welcome raporter
I made a box or two using the 1/4" dovetails but I now use the Oak-Park Box jig it works so much better and you can do it the same way if you want (blind slot ) plus it holds just like the dovetails do.
Bj :)
Ken I ordered this before finding out only a 1/4" would work, but hey we can't have to many bits can we. I will get the 1/4 ordered and see how it does. Bobj3, I make the box joints as well it's just that I have to keep trying different things. Lots of great help here, many thanks from a constant tinkerer.
When you get your new bit, post some pics of your project when you get it done. :D
I'm a believer in sears tools however, lately, either you order a tool only to find out 'bout 2-3 weeks later it becomes obsolete. As times change, seems like their (sears), service changes... for the worse!!
I know this is an old thread but how did it work out with the any old bit 1/4'' with this jig? I have a creaftsman dovetail jig too, not sure if it's the same part #, and am trying to figure which bit to use for 1/2" dovetails--I think it called for dovetail bit 26318 and a 7/16" bushing... I bought the brass bushing set which doesn't fit a Bosch 1617 without some additional adapter. Wonder if I should just look for a bit with a bearing that will fit that template?
Got an old 315.25790 Craftsman Dovetail Template (jig) for free, and had same problem with guide bushing (I use a Porter Cable router) and lack of availability of 26319 (1/4") and 26318 (1/2") bits. User manual is attached.
Have found that for 1/4" dovetails, the Freud 22-100 bit (7.5 degree angle) and the 5/16" bushing from my WoodRiver bushing set work. You may have to play with the shims on the template brackets a bit (add/remove washers) to get a good result. Adjusting the locknuts so the template is parallel with the edge of the horizontal board is key for flush dovetails.
Am working on the 1/2" dovetails. Already discovered that my 14 degree angle 1/2" bit will NOT work, as at the required 17/32 (for me, a "loose half inch") projection from the baseplate, the bit's cutters touch my 7/16" bushing. Have ordered a bit with an 8 degree angle and will report if that works.
Welcome to the forum Larry.
:) Hello and welcome to the forum, Larry
I have made many small boxes (lap desks) using this jig and 1/4" dovetail. I believe I have a 7.5 degree bit or two from Grizzly. Wood thickness up to 11/16". Just make sure to check your setup with scrap before final project work. In fact I think if I can put thicker wood into the clamps that would be the only restriction. The manual for this jig is online and use it as a guide.
1 - 13 of 13 Posts
