Craftsman mdl. 113.228160 lathe
11K views 15 replies 9 participants last post by  jw2170
I have a 12" Craftsman lathe mdl. # 113.228160 new out of the box. I discovered the spindle was out .015". I had it checked at a local machine shop and they found it was manufactured this way. In addition, the #1 morse taper bore is off even more!
There are new spindles out there but I'm afraid they all may have been machined that way.
Has anyone run into this problem? I hate to give up on a new lathe!:sad:
Take it back to Sears and get a new one. Have it checked- if it's out also, get the shop to write down what is wrong. Take that one back and get your money back and buy something else. The forum folks will steer you in the right direction.
BTW, Sears has all their tools made by contract manufacturers. If you look around, you will probably find the Sears lathe is like another brand. I have also found Sears will change a couple of things so all parts from the OEM won't interchange so you have to buy those parts from Sears.
I had that sears lathe and it was the biggest piece of crap I had ever used. First problem I had was I couldn't get the headstock and tailstock to line up with the same problem you are having. Second problem is it is a tube lathe which doesn't give you much stabliity. The lathe is mostly for doing spindles. The #1 MT is hard to find accessories for and if you upgrade later nothing you buy will fit the other lathe as they are mostly MT 2. I never did get it work even with my friend who was a machinest for 35 yrs. I bought mine used trying to save money. Well didn't save any and it ended up at the metal recycling place. I would get your money back and look at a Jet, Delta, Nova, etc. You'll be money ahead in the long run.
Bernie,
My brother-in-law got it in 1982 as a Xmas present and never took it out of the box. He gave it to me for free so I don't have anything invested. I think I'll take your advice and look for something else.
#16 ·
Welcome to the forum, Michael,
