is it proper procedure to use a 45 degree chamfering bit to miter the corners for a small decorative box? better on a miter saw, or table saw rather than a router table? thanks
Bob, I'm geometrically challenged! I don't understand why a 3/4" cutting length couldn't be used on 1/2 material.HI Frank
Just a note, the Chamfer Bits have a down fall, they are made for 3/4" thick stock the norm and as you know when you cut stock on a angle it gets longer so to speak..the thicker the stock the longer they are..that's why the MLCS bits work so well on any stock
Although theoretically possible, I don't think I'd recommend trying to cut 45° angles on the ends of narrow boards on a jointer. At least not without an auxiliary fence that could accommodate a jig to hold the work piece at 90° to the jointer blades, and that would keep the old pinkies well away from said blades, as well.
To re-address the original question, Yes. I'd do it in multiple passes, however, using a backer board and a sled or push block. Fence positioning is critical on the last pass, though, so as not to over-cut the resulting "knife edge". A feather board mounted to the fence can help to keep the stock tight against the RT surface.is it proper procedure to use a 45 degree chamfering bit to miter the corners for a small decorative box? better on a miter saw, or table saw rather than a router table? thanks
