1 - 11 of 11 Posts
· Registered
Hi guys,
I had explored this in the past.I was wanting to take a 3/4" straight bit and cut a groove 3" long in a flute.I make wooden flutes. So it 3/4" wide by 3" long by 1/4" to 1/2" deep. It would be just when you stop the router....having a radius or curved end on both ends of the groove...I am good so far up to this point....I want to make a piece to fit as perfectly as possible into the groove.It would be glued in place. How do I do this? Thanks a bunch in advance!!!
· Registered
cut a floating tenon to fit and slice or cut off the length the tenon to your happiness...
treat this as an inlay such as a butterfly/bowtie..
and extreme jig to do this would be a Leigh FMT Pro...
you could make your own jig...
to make a floating tenon it takes nothing more than a piece of stock to size and a bullnose or half-round bit
Reactions: jj777746
· Registered
It sounds like you have the groove already and want to perfect-fit a piece into the groove...?
Trying to picture what that would look like...can you supply a picture...?
Reactions: Stick486 and MEBCWD
· Registered
A picture of what you want to do would really help us help you
· Retired Moderator
Cutting the groove I think you already have figured out. I think it's getting the ends rounded that maybe has you stumped. If you are making a bunch of these I would make a long rounded tenon style piece like Stick suggested and then use a 3/8" radius bull nose (same curve as your straight bit) to round the ends and then cut slices off it the thickness you need.
· Registered
no bullnose or half round???
use a 3/8'' round over and your RT...
· Registered
Discussion Starter · #9 ·
Yeah I have the groove figured out...I just cut 3/4" groove or slot the length needed and stop.It will be rounded on the ends .I need to make a piece to fit into this groove.It is actually to make a repair where something didnt go like it was supposed to. Thanks !
· Registered
here's an image of a loose/floating tenon...
you can do the tenon in end or long grain...
Reactions: Cherryville Chuck
· Retired Moderator
Attach your workpiece to a backer strip or push block. That way when you push it past the router bit you'll greatly reduce or eliminate tearout. Routing end grain is really prone to tearout. You can make your pusher block so that a clamp can be used to hold your work to it. The clamp helps prevent the tearout more and well as making the work feed more stably past the bit and gives you something to hold onto. You can see what I mean by going to post #11 in this thread: https://www.routerforums.com/jigs-f...d-suitable-triton-rta-300-router-table-2.html
1 - 11 of 11 Posts
