After applying the second coat of butcher block oil to this board I discovered the joint shown below. Fortunately the gaps do not go all the way through. I examine these boards very carefully as I glue them up as well as following each sanding course and I have no excuse for having missed this.
The net result, I need to use a razor blade knife to clean out the joint, add more glue and re- sand this side. That is unless fellow members come up with an alternative. In the interim, I shall cast disparaging remarks on my eye sight.
