Thanks Eric, you are right the T101AD was a poor choice. I found a T144D in a drawer, tried it and it worked perfectly. Nevertheless, per your suggestion, I will order a package of T244D.
Photo shows 3/4" plywood template, I will use the Freud top bearing bit that I received today to clean it up.
In '85 had a top of the line Craftsman, I do not remember the model, and made perfect circles using a Craftsman trammel point. There is one for sale on ebay but the distance between the rods that attach to the router base are too wide [5"] for my Makita. Festool sells a simple trammel unit [483922] for $27 but I am not sure it will fit my router. I will need a trammel to cut the drivers' holes [loudspeakers] at 277mm - inner circle. Please see template.
Cheers,
Cheers,
