cutting depth
2708 Views 4 Replies 3 Participants Last post by  bobj3
I have to make a series of slots in 3/4 " material (pine) about 5-1/2 long all way through. I plan on a 3/4 " bit however can this be done in one slow pass or two? :eek:
1 - 5 of 5 Posts
Hi Grandasworkshop
I don't see why not BUT it's one of those things you need to just try out :)
If your bit is new and sharp it should be duck soup but if not it will take a pass or two.
Pine is soft but will dull the bit real quick with build up of pine pitch.
A good spray Teflon base bit lub or a good bit cleaning will help with Pine. :)
http://www.mailwareweb.com/sommerfeld/item.asp?n=bblub-2oz&d=99&b=2
http://www.mailwareweb.com/sommerfeld/item.asp?n=bbcl-16oz&d=99&b=1
Bj :)
Two passes in pine should make for a nice clean cut. For hardwoods stick to a 1/4" removed in a single pass for quality.
Thanks so much.I did not want to chance any thing like that in case it grabs and pulls fingers in
1 - 5 of 5 Posts
