You can cut it on your table/radial arm saw with a fine tooth blade or on a band saw.
You can cut lexan this way too
Mo
Mo
I had good luck, after trying various blades, by putting in an old dull metal cutting blade in my band saw. Have had decent luck with the router too, slow the speed down to avoid melting the plexi or acrylic material.Drick said:Not quite woodworking, but how do you cut plexiglass? Would a jigsaw do it?
Can plexiglass or acrylic be cut on a router? Would that take a special bit?
Drick
George II said:Will cutting acrylic be the same rules as plexiglass?
George II
George Coe
jjciesla said:I've always used tape to keep any melt back off the work. bob, does that Freud blade cut such that you don't need the tape?
Jim
