I took a piece of 1/8" plexiglas and used my router (along with the router guide from rockler). The template turned out perfect. I cannot get a good clean cut however. My router edge get stuck on the corners of the oposite side of the "X". I often over-shoot the edges.
Should I used thicker plexiglas? I though about using a larger router base, this would float over the entire template.
I have been using double-stick tape to hold down my piece I am cutting. I drilled/counter sunk four holes on the template, to secure with screws.
Any suggestions?
Any suggestions?
