CV 1800 dust collector
8774 Views 50 Replies 11 Participants Last post by  RainMan 2.0
https://www.clearvuecyclones.com/cyclone-bundles/66-cv1800-lh-1p-cyclone-bundle-with-filters.html
Well after studying dust collection this past few days , I’m thinking it’s time to retire my General DC , and upgrade to something that will improve the dust collection from my table saw .
From the videos I’ve watched , the cyclone clear view seems like a winner .
I’m going to order it with the optional 16” impeller assembly for more cfm . It’s a $100 upgrade , and the more cfm the better I’m assuming,unless it creates a problem with the cyclone effect . You’d think they’ve took that into consideration though ?
Now I can go overhead like I wanted to , and not have to worry about not having enough suction .
I’ve watched videos on the product, and although it seems kind of plasticky to me , no ones complaining about it so far , and I don’t want to pay the extra for an all metal one .
I have a 10’ ceiling , so heights not an issue for the system , plus as a bonus, I get to keep it tucked away in the far corner where I preferred to have it located .
If I kept my old setup, I was going to move it to the centre side on the garage , as close as I could have it to my table saw .
So now I’m just waiting for a shipping quote, which may be the deal breaker
41 - 51 of 51 Posts
I was concerned about vibration. Of course seeing as the power to the table saw will be mounted on the ceiling , twist kicks would make sense .
But it’s more than likely overkill on the DC .
I was going to use a twist lock on the cnc spindle though . Just for piece of mind , and because I have two.
Edit . Herb , almost forgot , the DC will be controlled by an IVAC system . The control box for the IVAC goes to a contactor in a separate enclose that will be plugged into the wall with a twist lock .
I tried the IVAC without an external contactor , and it kept on tripping its breaker because of the inrush current
https://youtu.be/95LBb2ii_WI
Instead of mounting the boxes face down mount them through their sides so that they face out. That's what I did with my ceiling DC unit.
Reactions: 2
Never even thought of that. Do a surface mount box and put them on their side . Geez , I don’t exactly think out of the box sometimes lol
Guys , I posted earlier that I sourced out an oil drum for the saw dust . But now I’m steering towards making a container out of wood with a sealed door .
Wouldn’t it be much easier to have a door that’s latched on the front of a wooden box , then open it when it’s starting to fill up , and just shovel the saw dust out into a garbage bin ?
I know it’s an additional step, but undoing the band at the top of the drum and actually having to remove the drum from under the Cyclone seems like a lot of hassle regardless .
I haven’t actually taken the band off yet to see how the lid comes off , but I suspect it’s a nuisance
Rick...I believe you bought the wrong barrel. The one you want is the one with the latch for the ring...the one you have needs a couple of wrenches.
If you build a barrel with a door, the sawdust will fall out when you open it...or never let it get above the bottom of the door.
Check out the hard cardboard barrels at Uline...
Reactions: 2
Listen to Nick, RICK! The first DC system I built plywood box and a roll out bin that held 70 gallons of dust. What a disaster, the dust filled up around the bin and under it. When I opened the door it fell out all over the floor. I used a scoop shovel and shoveled in into a wheel barrow. I had a trail of sawdust all the way out to where I dumped it. 2 wheel barrel loads, and a 16 gal Sop vac full. Then had to clean the dang shopvac filter, what a PITA. Now I have 32 gal garbage can,I put a 42 gal black plastic bag in it . It has to be weighted down so it doesn't get sucked up into the fan. Use a bent piece of formica around the inside of the barrel to hold it til it get enough sawdust to stay. Or some guys us a brick with a rope on it to hold the bag down.
I made a lid out of plywood ,routed a groove for the top of the can and put foam weather stripping in to seal it. The can sets on a dolly I made, so it has about 1/2" clearance below the lid. I wheel the empty can in place turn on the DC ,it sucks the can up tight and I slide wedges under the can to hold it. Shut off the DC, use a wire tie on the bag to hold it closed and throw the whole thing in the garbage.
Reactions: 2
6
Here are some pictures
Reactions: 2
I did a quick search for barrel clamps and this popped up from McMaster Carr https://www.mcmaster.com/barrel-clamps/closing-rings-for-steel-drums/ which has the quick release clamp. I did something similar to Herb with a ply top for a trash can. I made a "slip" ring epoxied to the underside of trash can ring and suspended the lid and cyclone on the wall. The can hangs about 1" off the floor. When I need to empty the can it drops to floor so I slide it out and dump it.
Reactions: 3
Nice neat job. Bob. How big of a can is that?
Rick,Have you measured your ceiling height an compared it to the height of the cyclone and fan o see if you have enough head room for that Can. It looks kind of high to me.
HErb
HErb
It's the standard 32 gallon.
Rick, avoid shovelling. Makes a mess plus you have to wear dust protection. A short piece of flex allows you to lift the lid enough to slide the barrel out. I like the cardboard barrels because they have to the quick release lid and are really light and cheap.
Reactions: 2
I’m liking that quick release idea ;)
41 - 51 of 51 Posts
