1 - 13 of 13 Posts
Oliver (Prof. Henry)
Yeah, I know. Dados should be cut with a router and a fancy adjustable jig. But sometimes it’s just quicker, faster, and easier to cut them on the table saw.
When I bought my set of Oshlun dado blades they came well protected and packaged but in a cardboard box. Since the set of 8” blades weighs almost ten pounds I didn’t think the box would last long. Plus, although it protected the blades well, it wasn’t really user friendly.
I went through several concepts in my mind always worrying about how strong a box was needed to hold the weight and how to make it convenient to use and store. I finally settled on a design that required minimal box strength to work and then planned the project in Sketchup so I wouldn’t screw up when I cut out the parts.
The heart of the box is a vertical blade holder / handle made from 3/4” plywood. It really carries all of the weight. The base of the box is 1/2” MDF and the rest was made out some re-claimed 3/8” plywood I had on hand.
You’ll notice the sides have a 10º angle on the back. It serves two purposes: First, it makes the footprint a little deeper so the box doesn’t fall over from the blade weight; and second, it gives me a staging area to set up my dado stack and check against my stock size before putting the blades on the saw.A removable 5/8” post is used when stacking the blades. The post stores inside the box when not needed. The blades and shims are stored on the center 3/4” panel with a 1/2” bolt and wing nut.
A simple sliding cover closes the front and I glued a printout of which blades to use to set up a cut to the inside of it. The finished box with blades in place weighs about 13 1/2 pounds. I think it will be secure and convenient storage for the dado set.
that's sweet Oliver...
but why no roll top...
Discussion Starter · #4 ·
Interesting solution Oliver. I'm not satisfied with the setup in my box either so taking a good look at this. By the way, what do you think of the Oshlun blades? I'm looking at some of their other ones.
Very nice, Oliver. The hinge broke on the cheap plastic case for my Delta set, and something like this would be a great replacement. My set has a bunch of shims, so I need somewhere for those to go, too. Thanks for the ideas.
Nice, Oliver.
I ran into the same thing with mine several years ago. I just constructed a simple lidded box out of 3/4" pine with a dowel in the center for the blades and a separate one in the corner for the shims. It was "rude, crude and socially unacceptable", but it did the job at the time. I have never felt a need to fancy the box up, even though that has always been the intention. Now you've got me thinking....
Reactions: Gaffboat and furboo
Discussion Starter · #9 ·
I chose the Oshlun blades because they have full body 6 tooth chippers and the price was right at around $100. I have only used them a few times but I've been happy with the very clean and accurate cuts.
I was thinking more on the lines of a Iris opening because it is Oliver but then the box would need to be bigger.
Reactions: Stick486
Sent from my iPhone using Tapatalk
1 - 13 of 13 Posts
