1 - 6 of 6 Posts
I use two edge guides when routing a dado along a long piece of wood. They hold the router steady from both sides of the wood to prevent any wandering. See attached photo
That's one of the jigs on my to do list Jim. I tried to make one from the edge guides that came with my 2 big Hitachis but one has fixed rods and they weren't long enough to use the part from the other one. I had to do a job just like the one you show and as careful as I could possibly be with the single edge guide I had a few very small strays off a straight line.
Thanks for the tip, William, I have done the one on theblock of wood before, but never thought about the one on the router base. Learn something new everyday.
Dado guide (groove guide actually)
Jim
Owners of DIY routers generally don't have the luxury of being able to buy a second edge guide. Many DIY router manufacturers use the same simple guide shown in my photo and having two of them wouldn't help. I made my own second edge guide (also shown in the photo) and use it when cutting mortices with a hand-held plunge router.
It will work just as well for the application you describe.
PS. The cut you show is a groove: a U-shaped cut with the grain. A dado is a U-shaped cut across the grain. Why two different names for what is essentially the same cut. When my grandfather cut a groove he did it with a wooden plane. When he cut a dado he did it with a tenon saw and chisel. Two totally different approaches and hence two different names. The names have lived on.
Denis Lock
1 - 6 of 6 Posts
