21 - 36 of 36 Posts
· Registered
Woodstalk was an excellent idea ahead of it's time. I have a feeling it will return in the future. At this time it is not a profitable item for Dow. Let's all hope it returns soon.
I agree with Mike, I think it will be back too. And I also like the simple dado jig system where I take the ACTUAL size of the shelf (a sample) and place it between the "rails" when setting them. Dado comes out exactly. I got the idea from Pat Warner, who also made me a nifty little base for a #7310 trimmer. I tossed it in a drawer a year or so back but brought it out and am finding neat ways to use it.
But thats another thread.
The wheatstraw will come back when we learn we can make ethanol from prairie weeds and shrubs and don't have to use expensive corn and grain and when city folks discover they can cut their water bills be simply catching and saving rainwater from their roofs.
· Registered
Discussion Starter · #22 · (Edited)
Hi Tony
Yes ,you can use the jig the same way as the Rockler one,you just need to add a fence out of a true 2 x 4 and put in the brass guide in the router table.. :) you will need to make the jig a little bit wider and add some slots for the hold downs..with a tee slot bit.
Plus it will only cost just a buck or two for the stock..unlike the Rockler one for 120.oo dollars..
Router Table Crosscut Sled - Rockler Woodworking Tools
Dado Jig
We have all seen many jigs to put in a dado for shelft(s) in a book case or cabinets.
Most have two boards that hold the router in place,from moving from side to side, like the one Norm made on his show most will jam when you push the router up the tack .
This one will Not jam because in runs on the brass guide that is true unlike most base plates on the router base.
They stamp out the base plate and it's not a true machined part.
This jig will take that error out and you will get a true slot,right on the button every time.
You can make a quick guide to use with this jig with 1/2" MDF and a dado slot and 3/4" plywood cut off stock to hold the spacer guide from one slot to the other.
In that way you will get a slot every 12" or what every you want it to be.
We all know that plywood is not a true size that's to say that 3/4" plywood is 23/32" and we need to use the right bit size to get it to fit right,same with 1/2" and 1/4" plywood.
I try and make most of the book cases or cabinets 11 3/4" wide so I can put the slot in both at the same time and then split the 24" plywood and end up with both sides that are dead on.
Then use a face frame to cover the plywood ends and to hold the shelf sq. and add support to the shelf ,with a T & G bits you can put a slot in the shelf and the face frame.
T & G bits ,set it to cut 1/4" deep on all slots.
You can also use the T & G bits to make a 1/4" spline that's 7/16" wide and it's dead on 1/4" thick and it will work great to hold the shelf and face frame as one.
I have put a link or two for the bits you need to use and the bits you need to make the jig and the brass guide, It true that Harbor Freight has a better price on the brass guide set, but it will not come with the 1" O.D. one you need to use for 3/4" plywood and this jig.
Grizzly.com® -- Home for the bits and brass guide kit.
Plywood bits H5559 and H5558 at a good price
1" bit 1/2" shank C1017 also a good price
Brass Guide Set H3134 it's bit high in price BUT has the 1" guide you need.
If you need more info please ask :)
Plus some other snapshots of jigs, see below ▼
NOTE*** drawing below/plans
http://www.routerforums.com/jigs-fixtures/4371-details-dado-jig-please.html#post41464
Router Forums - View Single Post - Dado Jig
Bj :)
Snapshots are out of order sorry about that, out of my control.
· Registered
I've read this post from start to finish, I apologize if I'm missing something. I like BJ's jig and would like to try and build it but I didn't see any instructions on HOW to build it. How do you cut the STRAIGHT 1" hole in the middle of the jig? Do you need some other type of guide to cut it straight? Sorry, just a little confused. Thanks....
· Registered
Discussion Starter · #24 · (Edited)
Hi Goldglv
Just pop in a 1" router bit in your router table and drop the board on the bit,,the fence will keep it running true.
If you want to go the extra mile use a wider board and put in two more slots ( 3/8" bolt size ) for a fence and hold downs..
Doing the extra steps you can use the jig on the router to put in dado slots on a 45 deg. a angle :)
http://www.rockler.com/product.cfm?page=22009&filter=router table crosscut
· Registered
Discussion Starter · #26 · (Edited)
No router table LOL :) no big deal :)
You can clamp two boards to the board you want to put the slot in ,,like side runners for the out side of the router base plate, then drop and slot..
Note the clamps ( 4 or 6 )should hold it up and off the work bench so you should not need some scrap stock under the board..
If you don't get it dead on it's OK because ,you can use the stop/start block on the end of the jig to make it a true 90 deg. to the slot...:)
Bob,
Thanks for responding. Just have one issue....don't have a router table....any suggestions? Thanks again....
· Registered
Discussion Starter · #28 ·
Hi
True, but the bit is :) ,just put the router at one end of your clamp down boards and then the other end then do it one more time just to make sure it will let the router slide by easy and not hang up and then do it one more time when your sure fire up the router and plunge in and run the pass..
So to make the groove I would be using the base of the router as my guide? Even though it MAY NOT be perfectly proportional? I'm obviously a novie, sorry for all the questions....
· Registered
I do have the brass fittings you spoke of earlier, I would just use my router to create a 1" groove so I could use my brass fitting as a guide, correct?
Just like you said, start at one side, then start at the opposite side....this will get me a straight 1" groove?
· Registered
Discussion Starter · #30 ·
Hi
correct?, yes
· Registered
I apologize if this is gonna confuse the issue but I built the woodsmith adjustable guide and it works quite well. I did make the modifications to use a 3/4" bushing and 1/2" bit instead of using the base plate reference. What I don't like about it is that it won't do one smaller than 1/2" without performing some unnatural acts or something.:bad: I intend to rebuild it with a 1/4" bushing and 1/8" bit one of these days.
I tried to upload the pdf but for some reason it wouldn't attach. Here is a URL though:
http://www.woodsmithshop.com/download/204/adjustabledadojig.pdf
· Registered
Hi Goldglv
That 1" grizzly bit you mentioned, C1017 doesnt look like it is plunge-able? Is it? I probably only will ever need 1 1" bit, i better make sure to get the right one ;)
· Registered
Discussion Starter · #33 · (Edited)
Hi Dave
No, it's not a plunge bit but it will do the job but you can order a 1" plunge bit from MLCS..
MLCS plunge cutting straight router bits
jUST a note the 1" bit you will use it over and over for many jigs, once you see how well this type of jig works..
All that's needed is a slot and the guide in the router table and you can do many things on the router table easy and safe..i.e. your own box joint jig..that can be use it to put in 1/8" to 3/4" box joints..and all done for peanuts..not to say anything about making you your own pocket hole jig that can be used on the router table and aging for peanuts..:)
http://www.routerforums.com/jigs-fixtures/2470-pocket-hole-jig-router-table.html
· Registered
Hi Dave
Very cool. Thanks bob!
· Registered
I just pre-drill a 1" hole where I want the slot to start so I don't have to wrestle with a bit that's not made for plunging. I have a similar Dadoe jig, the thing I did different is I fixed the bit guide to a big U shaped table and just slide the stock that needs the dadoes in it to a stop rout the dadoes in all pieces more the stop do it again. After I get my 10 post I'll post a picture
Chrs
21 - 36 of 36 Posts
