41 - 53 of 53 Posts
@DaninVan...
I used some over sized fender washers and bored them out to 5/8''...
I still say do this freehand w/ your T&G set...
Mike; yup that's my plan. Gary mentioned the shaper head late on in the conversation; it's the perfect solution. i have one, but not the knives i need for it, so back to plan A...my original question " is it safe"? Stick and Charles told me to just do it! ;)
(i heard you guys had a bet going that I couldn't find it...)
I'm shocked. I saw a picture of your shop once and I was betting that you don't even know what the floor looks like anymore.>:)
I saw it too...
how he even finds the light switch is a miracle...
Maybe there's a strategy...probably where he hides his "stash"...
Reactions: Herb Stoops
I didn't need to turn them on; lots of daylight with the garage door open. :)
as impossible as it looked to find or even get to you must open it from the outside.. eh...
oh yes...
his stash...
hidden in plain sight...
it'll still take heavy equipment to get to...
Discussion Starter #52
Charles; you're a genius! How did you even remember it was in there???
https://www.routerforums.com/tools-woodworking/143903-dado-stack-question-2.html#post2143091
I do have it... it's more of a bushing than a washer. It's 1.5" in dia. and .310" thick, about 5/16".
I stacked my two outer dado blades horizontally with that bushing in between. My caliper suggests about .29+/-" as the space equaling the tongue after cutting. That'll probably shrink a bit once I mount them on the arbor and tighten them down.
I may have to mount a couple of chippers to get a wide enough cut ie all the waste removed across the thickness of the boards.
(*does the Happy Dance*)
I use mine occasionally. Maybe more like rarely but once in a great while it winds up being the best tool for the job.
41 - 53 of 53 Posts
