I'm almost done with my router setup, I just need to finish laminating the top and putting in the T tracks, and I need tp cut the holes for the DC and electrical hookup. I building my version of the very typical "Norm" router station, made for taller people like myself.
I wanted to see what you guys think about the DC setup. The typical setup I see for this style of station is one large opening at the bottom of the router area and then a Y fitting connected to 2" hose at the top, so you get above/below DC at the same time, which I want.
What I've noticed, though, is that my porter cable router pulls air in the top and out the bottom (towards the bit), I'm guessing it's some built in heat reduction to blow air across the motor. If I put the 4" port at the bottom, I'm fighting against that built in air flow.
So I'm thinking of putting the DC at the top of the router area, with a blast gate/fence with an opening at the very top, maybe even a sloped piece starting at the bottom and leaning back towards the opening at the top, that way, the air flows in through the door, up towards the top, and then out the back, it should still pull air down through the router plate, but hopefully compliment the natural airflow of the router and not fight it.
I mention all this because with my last setup, I had my router in the extension wing of my TS with a simple box around it. I used a shopvac at the bottom trying to pull air down the hole, but I noticed my router always got very hot when I did this, as oppossed to when I had no box on it.
Comments?
Comments?
