I'm in the process of building a night stand for my wife. Two nights ago I was fighting with a machine and then got called in for supper and came out and made a really rookie mistake because my brain wasn't fully involved in what I was doing. I cut the crosspieces for between the legs and forgot to add on the lengths of the tenons. I had already drilled the mortises for the top pieces into the legs with my drill press mortise attachment so I was committed to tenons already. I thought that it wasn't a start over type catastrophe, I'd just switch to floating tenons instead. I just needed to mortise the ends of the cross pieces to match.
I had just finished reading an article in FWW about one of the authors wanting to use his dedicated mortiser for a project but it didn't have enough height capacity. My screw up highlighted a major difference between using a dedicated mortiser and using a drill press mortise attachment. If someone is thinking about buying one opposed to the other this is something they may want to consider first. A dedicated mortiser has a height limitation of around 6-8 inches it looks like (I couldn't find a spec on that in their ads). A floor standing DP with attachment has a height limitation of a little over 3 feet if you turn the table to vertical or move it out of the way. This allowed me to use the DP to make mortises in the ends of my 13 1/2" long pieces instead of drilling and chiseling.
