1 - 20 of 20 Posts
Discussion Starter #1
My latest box, 6" x 3" x 2 1/2" high.
Made from a scrap drawer blank from a much bigger bandsaw box, sliced the lid off and routed out the inside.
EDIT, just noticed its a bad pic and the reflection on the lid makes it look half bare of varnish. It isnt.
I admire you guys that can do the small detailed stuff. I can't even put hinges on straight on something like that.
Super Moderator
John
Well done , what kind wood :)
Very nicely done! And the burl on the top is extraordinary!
Premium Member
A fine looking box, did you take any shots showing the making?
Discussion Starter #12
Harry, no I didnt take any pics along the way.
I make my stuff as I think of it, no plans or even drawings, just as the mood takes me.
Because of this I have a LOT of failures, so theres no point of taking pics when the item eventually goes in the fire box.
But this one was really simple. The blank, as i said, was just the cut out from a large bandsaw box drawer. I cut the lid off, and then set up some pieces as a a box stop on the router table and then just routed it out about 1.5 mm a time untill the base only had 10 mm left.
A quick skim around the edge with a pattern bit and its done.
You do some great looking work with the plywood edges, Bob. Another idea stored in my "want to do" folder. Thanks.
Paul
Very nice, Bob. The rounded interior and inset in the lid is interesting.
Hey Bob, you did a great job on the box. What type finish did you use? Always glad to see what you have produced. Malcolm / Kentucky USA
Discussion Starter #16
Malcom......, still using home made wipe on. But results vary a lot.
I have two theories about it, but so far am not able to make my mind up.
1 is I think its because I keep buying different makes of poly.
My favourite shop shut down about 6 months ago and I cant get that make anywhere else so am trying small tins of different makers.
2 is I think temperature appears to make a huge difference to results.
Last year in high summer it was well over a 100F and I couldnt get the stuff to stay wet for more than a minute. I ended up doing that one in a room with the air con on full and then it worked really well.
Right now the temp is around 40F and its playing hard to get again.
But I am also on yet another maker. This one has a very slight greenish tinge to it when I let some dry in a clear plastic cup, whereas others dry with a brownish colour, despite all of them being labelled as clear.
Ten gees....., The rounded corners are a result of the whole interior being carved out of a solid block on the router table using a long straight cutter. I like the curves, but its very difficult to stop the ply from burning, and almost impossible to sand the burns out afterwards (sigh). But it looks nice from a distance. The lid is also shallow routed and then flocked, but only after posting the pics did I realise that the one with the box open is a very poor shot and doesnt show the lid off any where near as nice as it actually is.
Ross
Beautiful work.
Nice effect with the ply....
1 - 20 of 20 Posts
