Deer panel 500x250x35mm
4043 Views 31 Replies 14 Participants Last post by  Whitey.
Walnut Deer panel 500x250x35mm
Just finished this Deer panel. rough cut 3hrs, finish cut 13hrs
First pic is 35mm slab clamped to table ready to start.
Reactions: 4
1 - 20 of 32 Posts
Second pic rough cut done 3hrs
Reactions: 2
Third pic finish cut was 13hrs. Stained then finish applied.
If you don't mind sharing, what tool are you using on the finish pass and how much step-over?
Very nice!!
I need to do some more 3D carvings.
Very nice! Did you create the file?
David
Finish pass tool is 1.0mm tapered ball, the stepover is 0.2mm
This is probably over kill. Advantage is it does excellent detail and a smooth finish with minimal post sanding. The down side is long run time.
David
No, I am currently CAD illiterate. I purchase STL files online at ebay, etsy anywhere I can find what I need.
Reactions: 3
better than very nice...
That doesn't take away from the work, not at all. I was just curious.
Do you run dust collection the entire job or just occasionally vacuum the dust/shavings?
David
David
Saw dust is a problem, especially the very fine stuff. So I run the vac the entire time.
Reactions: 2
Would you point me in the direction for where you got this file?
This one was on eBay. Search stl router.
https://www.ebay.com/itm/3D-Model-S...-/124178572598?_trksid=p2349624.m46890.l49292
Will this be wall art or serve some other purpose? Gorgeous...
Wall art in a log home.
Dan That is a nice clean carve. It will look good on the wall.
I find it hard to fathom... running a router for thirteen hours straight. I wouldn't think it would last very long with those run times. Just amazing. Beautiful job!
1 - 20 of 32 Posts
