Descktop Pencil Holder
3234 Views 20 Replies 11 Participants Last post by  papasombre
12
The story behind this little "What is it", is that I had this 1/2 log piece that came with the lumber stash,pic1. I didn't know what kind of wood it was so I cut a about 6" off the end to clean up and see what I had. It turned out to be Maple. I didn't want to just throw away the piece so thought I would make a band saw box out of it.
So I cut the bottom off, cut out the center, glued up the sides and reattached the bottom. The cut on the bottom looked ugly so I made a molding and then made some feet for it and called it a desktop pencil holder.
The finish is 2 coats of spray shellac, and 6 coats of water based poly thinned 50/50 with water. I did stained the base/feet ,because it looked better next to the bark.
Not my finest work, but I saved it from the trash bin.
1 - 20 of 21 Posts
That’s quite unique Herb , nice job. I’m wondering the left over piece could be sliced and used as dividers ?
Reactions: 4
Rick,you might just have something there. Good idea, I had not thought of that. I will check that out.
It’s quite wide . My concern was they would fall over . Thought a couple of dividers would do the trick
1st rate Herb..
Reactions: 2
Not your finest work is still better than a lot of my finest work,Herb. And imo would look good on anyone's desk. James jj777746
Reactions: 2
Nice work Herb.
Herb,
I like the rustic look with the bark still on, I think you might have started a new trend for pencil holders
Dan
Reactions: 2
Very nice work Herb!
Thank you for posting the sequence of your creation. I think dividers would be a very nice touch.
Great idea Rick.
I like it, Herb. I have some firewood that I might have to try that with. Did you partially sand the bark?
Fine idea. Dividers would help keep pens and pencils upright. Now, make some pens to go with it. I just looked through my wood stash and could make about 137 of those. Just a guesstimate.
Reactions: 2
No, The bark side I just blew off the loose stuff with compressed air, and sprayed it a couple of times with shellac, then brushed on the thinned poly. The Poly wants to foam up a little when it fills all the nooks and crannies, so after I get done coating I take a small artist brush and pick off the foam so it doesn't dry white. After several coats it starts to shine.
I don't have a lathe or do any turning. That is a whole nuther world. LOL
Reactions: 2
I have often thought that a person could make a bowl or vase, by putting 2 pieces back to back. and have bark allway around.
Reactions: 2
Herb, Great Job as usual. How long can you keep up the new ideas you show us.
I will try,Bob, to me the fun of it is to see if I can do something different every time. Then try something else the next time. right now I am making a bunch of wooden block planes, I did this several years ago and it was a hoot, they are all gone but one so I am using it for a pattern to make some more, and there is a new design I am going to try too.
I am glad all you guys like what I do, that will maybe stimulate some ideas of your own. Merry Christmas everyone.
Reactions: 3
I hope you have a good Christmas Herb . I’m on call , so it’s going to be a quiet one for me .
I don’t have any kids, so I buy the neighbor kids presents .Macie is the oldest at 5 , and I really want to build her something rather than buy her Barbie dolls .
Was hoping to make her a toy chest next year . With any luck I’ll have the laser engraver back on line , and engrave all her favourite characters on the lid etc
Reactions: 2
Rick, I went back andtook your advice and added partions inside the pencil holder. Thanks for the suggestion.
HErb
Nice job Herb!
where's the pencil sharpener...
Reactions: 3
after careful consideration...
can you make another in a downsized version...
that one won't fit in the shirt pocket...
1 - 20 of 21 Posts
