Desk build
3061 Views 22 Replies 8 Participants Last post by  roofner
I have drawn up a sketch up of my design but I don't have sketch up pro can I post here?
1 - 20 of 23 Posts
Herb says it's okay...
go for it...
Reactions: 3
Posting is great, fencing not so much!
I'm with Stick. If Herb says it's OK, it's good.
Reactions: 2
I don't think it will make a difference which version you're using. Give it a shot and we'll see.
Getting close to finishing the posting, will be moving on to fencing if you don't hurry~!!! :jester:
Well here goes not much space in room its going in. So desk is going to be tall 6 ft. Also taking a page from Mikes build of his bench using the solid wood panels. I''m going to use 3 20 " by 6 ft these will be the up right pieces. The right bottom will have a door not in plans yet. Also a keyboard tray under bottom shelf on left mounted on 2 drawer slides also not on drawings.
Here are 2 sketch ups one has dimension the other just drawing.
Can't view a single file.
Joat you need a sketch up viewer or sketch up program. I will put them as pdf files tonight.
I already have a sketch up program, but it sure doesn't work with that.
So is there a question or something you need help with?
Moving some wood and a chair into my shop is all I can come up with just now. When can I expect you?
Thanks,Gary, that worked for me.
Started build cut all the shelf frame pieces . Ready to start assembling frames. Then drill holes to attach frames to sides.
I assembled the shelf frames for the right side of desk . I am going to bolt the frames to the sides and middle supports. So middle frame support are not on yet because I'll need to drill holes first and put 5/8 inch particle board on top. The frames are 3/4 short because I'm going to put a suto face frame in front. Here is a picture of the frames.
I got all the holes drilled in the frames. Drilled the right side holes to connect shelf frames fit good. I did make one mistake forgot to account fot 1/2 mdf top shelf will be a 1/2 short. Instead of 6 inches it will be 5 1/2 no big deal. Trimmed the frames to accommodate the 3/4 inch face frame piece. I'm going to pick up 1/2 inch mdf for on top of shelf frames.
I would think the large of a knot would impact the strength of that corner.
1 - 20 of 23 Posts
