DeWalt 611PK
1 reading
8.8K views 9 replies 4 participants last post by  bobj3
Just a review on the DeWalt 611 router
All I can say WOW and WOW one more time,, I rate it at 9.5 stars out of 10 stars.
I did hold back the 1/2 of a star because it's a bit hvy. but that can be a plus also for some jobs..with the plunge base fixed in place.. :)
DeWalt DWP611PK
Standard Router Base
Plunge Base
Specifications:
* Rating: 120V AC
* Amperage: 7.0
* Horsepower: 1-1/4
* No-load RPM: 16,000-27,000
* Collet Diameter: 1/4"
* Plunge Stroke...
Fixed Base: 1-1/2"
Plunge Base: 2"
* Depth Stop: 5
* Spindle Lock: 12 Position
* Base Dimension: 4" Square
* Weight: 4.1 lbs
Features:
* Durable 1.25HP motor delivers the power to meet the toughest applications.
* Variable speed control feature enables bit speed to be optimized for changing applications.
* Soft-starting motor features full-time electronic feedback that maintains motor speed through the cut.
* Dual LED's and clear sub-base ensure maximum visibility in operation.
* Adjustment ring enables controlled bit depth changes to within 1/64" (fixed base only).
* Plunge base incorporates fine-tune adjustment rod for precise depth setting.
* Large, low-pressure spindle lock button allows for comfortable, single wrench bit changes.
* Multiple shaft-lock detents enable quick and simple bit changes.
* Depth ring and clamping mechanism combine to ensure motor remains locked in position (fixed base only).
* Spring-loaded release tabs allow for quick base removal (fixed base only).
* Motor can be transitioned quickly and easily between fixed and plunge bases.
* Overmolded rubber handles provide a comfortable and secure grip (plunge base only).
* Allows up to 1.5" of depth travel with standard base & 2" with plunge base.
* Aluminum motor housing and base construction provides long term durability.
* Extended sub-base provides greater work surface contact for improved user control (fixed base).
* Large plunge base platform provides added stability for heavier applications and sub-base accepts universal template guides.
* Extended 8-slot 1/4" collet maximizes surface contact with router bit shank for a tighter grip.
At 179.oo plus shipping â–ĽShipping Weight: 10 pounds
Ah.... good news at last. Thanks for the update Bj. Now for the ultimate question. Do I trade my Trend 4 for the DW 611 or stay with what I have? I only allow myself 2 routers unlike some folks I know :sarcastic:
Hi Bob
I Would say stick with what you have :) the T4 can be use in many ways,ski jig,with all the light you need and it's light for the small jobs but has a 1 1/4HP motor also...and it only cost 1/2 the price of the 611 but you can't have to many routers Bob..the 611 has a small foot print , it will not take up to much room..and it's only money and you can't take it will you but you can pass the router down..unlike money :) that dirty green stuff that's just like water..:)
BJ,
For those of us who currently own neither the 611 or the T4, how do we choose which to buy? For those of us that own Colt's, how would that fit into your recommendation?
Or more precisely, in your words, which should we buy today and which should be put off until tomorrow? <g>
#6 · (Edited)
Hi Jim
That's hard one for me,I would say
1. T4
2. DeWalt 611
3. Bosch Colt
The 1st and the 2nd are both plunge type routers but the 2nd is both the 3rd is fixed base only and the 1st.is plunge base only, so I guess it comes down what you want to use the router for, all 3 are great trim routers but number 3 can be installed in a router table very easy, I have not installed the DeWalt in a router table (yet) but it looks like it would be installed easy with the plunge base like it's big brothers ....once the springs are removed from the plunge base..
But you know me ,,,you can't have to many routers in the shop :)
I should note that Porter Cable has jump on the band wagon also but I have not checked it out..............
Hi Bob
Sounds good , let me know how you are going to do that :),,when I go they are going to put me in a (BIG) pop bottle rocket and shoot me off.. :) so no hope to put it in my pockets.. :)
