1 - 7 of 7 Posts
My new DW625 does not directly hold my 30mm round guide bushes. Do people use a sub base to hold them, or the DE625T10 adapter?
Or this from Rousseau. The removable center ring is a nice feature.
Discussion Starter · #4 ·
I have a subase for my Elu Mof177. It fits the Dewalt, so I will probably use that. I saw the DE625T10 on Ebay, I love accessories, but enough is enough, or is that a James Bond film.
I picked up a set similar to the HF set from Amazon UK recently. Wall thickness varied as did projection but ODs were OK and they are certainly very cheap.
Are the Freud FT1100 Template Guide Adaptor Plates relevant to DW625s ? In other words, would they fit a DW625 enabling use of the HF type guide bushes?
Cheers
Peter
To avoid confusion these guide bushings from HF are "PC style".
I find that the "tricorn" plate deWalt supplies as an accessory is prone to moving a bit. I'd recommend splurging on a Trend GB/5 sub base if you can afford to lose a bit of cut depth as this can be quickly and accurately centred. It also gives you an bigger base making the DW625 a bit less tippy
1 - 7 of 7 Posts
