I have a Dewalt 625e Router with variable speed control on it. I want yo bypass the speed control and run directly off the mains supply. Can anyone help please.
Usually this is done when it fails...are you planning to use an external speed control for some reason...?
Sounds like you've got something in mind...
Thankyou very much for your help.Can't give you specific wire configuration but what you want to wind up with is hot coming in from the cord would go to the switch...then from the switch to the hot brush...the other brush wire would go to AC return/common back to the cord.
But before you proceed, please continue your research to try and find specific wiring changes for the 625...and verify what I've described to make sure you don't fry the router or, worse, yourself...
When you bypass the speed controller the router will fire up at full speed (check your specs)...this means you will not be able to operate any bits greater than 1" or so...check router speed charts to make sure you're not spinning up too big a bit...for example, you will/should not slap on a panel bit...
