Dewalt DWP611PK + Porter Cable Dovetail Jig 4212 Compatibilty?
15K views 22 replies 6 participants last post by  iamnutzy1975
Hi,
I hope this is the right forum. Apologies if it is not.
I just purchased the DWP611PK and the Porter Cable 4212. I was reading both instructions and the 4212 says I need a 1/2" collet router. I looked at my router's instructions and it says I have a 1/4" collet router. Is there any way to make these two compatible?
TIA
The guide bushing won't be an issue. Finding the 7 degree dovetail bit in the PC standard 17/32" width with a 1/4" shaft might be a little tough. If you have difficulty, the free supplemental manual for the 4200 jigs (available here 4200 Series Dovetail Jigs) lists other bit combinations that may be a little easier to find in 1/4" shaft.
The supplemental manual is worth the download.
The guide bushing won't be an issue. Finding the 7 degree dovetail bit in the PC standard 17/32" width with a 1/4" shaft might be a little tough. If you have difficulty, the free supplemental manual for the 4200 jigs (available here [.portercable.com/jigs/dovetail/]4200 Series Dovetail Jigs[/]) lists other bit combinations that may be a little easier to find in 1/4" shaft.
Great! I was ready to box this up and return it to buy a Bosch 1617 and an adapter plate. Might be overkill for an occasional once in a blue moon user.
Rich, the first link BJ posted has the two bits you need in 1/4" shank for $15. If you do decide to return the 611 do it now because Bosch is offering an additional $25 off right now.
#14 · (Edited)
Rich, a picture is worth a thousand words. I am very happy with my Bosch 1601, two 1617's, two MR23's and Colt. If it is in your budget to do so go for the 23. Bosch featured this photo on their FB page, they also shared it with all their subscribers. :)
that's a beautiful setup! it was late last night when i was looking at router prices. i thought the mrc23 only cost about $30 more than 1617 but i was looking at the mrp23. anyhow, i ended up buying the 1617. :) time for a pat warner clear sub base plate so i can use my porter cable template guides that came with my dovetail jig (4212) thanks again!
#16 · (Edited)
My first 1617 (used, but not very much!!) came with a template guide adapter (Bosch RA1126 Templet Guide Adapter) and template guide bushings (Bosch RA1125 7-Piece Templet Guide Kit). As a novice, i saw the pop-out design and didn't think they could possible work as well as the screw-type so for months i only used PC style adapter.
In the last few months, i've been using them more and more. They allow greater plunge depth since they are flat on top, no possibility that they will come unscrewed, and i don't have to contort into a small opening to grind off my skin on the knurled nut. Quick and easy to change and i've never had an issue with them at all. I still use PC style guide bushings on occasion, but less and less often--not even with the PC dovetailing jig anymore.
Your mileage may vary.
My first 1617 (used, but not very much!!) came with a template guide adapter (url removed cpotoolsdotcom/bosch-ra1126-templet-guide-adapter/bshnra1126,default,pd.html?start=3&cgid=bosch-router-attachments]Bosch RA1126 Templet Guide Adapter) and template guide bushings (URL removed cpotools.com/bosch-ra1125-7-piece-templet-guide-kit/bshnra1125,default,pd.html?start=4&cgid=bosch-router-attachments]Bosch RA1125 7-Piece Templet Guide Kit). As a novice, i saw the pop-out design and didn't think they could possible work as well as the screw-type so for months i only used PC style adapter.
that's good input Earl, thank you. So you use the RA1125 with the PC dovetail jig with no issue(s)?
#20 · (Edited)
Hi
No need to use a bushing if you use a bit with the bearing on it and no need to center the bit up in the center of the bushing ,the bearing will do all the work for you and it is always dead on with the cutters on the bit :).
Pus the real plus you can take off the bearing and put them on other bits if you want..
2 PC Dovetail Router Bit Set for Keller Jig 1633 1643 | eBay
#22 ·
Hi
No need to use a bushing if you use a bit with the bearing on it and no need to center the bit up in the center of the bushing ,the bearing will do all the work for you and it is always dead on :).
I won't need them once i get cozy with the old Incra set-up i bought last week. Got the 16" positioner, fence and right angle jig for $100. Got the initial set-up done, and used it this morning to run the dados for a few Christmas boxes...it was very user friendly. Would have liked to try the dovetailing on it but i didn't have the time or spare material to experiment. Next week--when it's not last minute gifts, we'll get it running. Since the world didn't end on Friday i'm scrambling to finish up some stuff i didn't think i'd need to do!!! :D
