The only plunge routers detachable from the base are the kit ones. The rest are one unit. Most plunge routers don't need to be in a lift. A lot are above table adjustable and the rest can be adapted, such as with a RouterRaizer.
Thanks. After I looked at the pictures of the various units it became obvious from the looks of the case.The only plunge routers detachable from the base are the kit ones. The rest are one unit. Most plunge routers don't need to be in a lift. A lot are above table adjustable and the rest can be adapted, such as with a RouterRaizer.
Any suggestions to look at for a stand alone?I have a 621 with the plunge kit and find it very reliable and useful as a general router. As Chuck pointed out it is not one to use in a lift. I would check out stand alone motor systems if you want to keep it in a lift on a table.
must be an older 7518...@joea
I have a PC 7518 in my Rockler lift and have no problems with its performance but if I were starting over I would follow Stick’s suggestion.
It is Stick. Don’t recall when I bought it. It was recommended by Rockler at the time as it fit their lift very well and was available as the motor only. I don’t use it regularly but when I do it gets worked.must be an older 7518...
