distance between miter track and bit
10K views 9 replies 9 participants last post by  Mike
I am replacing my router table top and am not sure of the distance needed between the miter track and the router bit.
Hi. Welcome to the forum.
As close to the insert as you can get it. However, unless you intend to use it for a feather board I wouldn't bother. A sled works better in my opinion and requires no setup. If you intend to use a mitre gauge and use the fence at the same time they have to be square to each other and the bit exposure has to be right at the same time which can take a while to get right. With a sled you only have to worry about the bit exposure. The sled takes care of the squareness for you.
Check on the Incra web site. If you decide that you want to use one of their jigs then you have to be within a certain distance. Might as well plan on it because it won't matter if you never get one but will matter if in the future you decide you want one.
There are differing schools of thought on miter slots/T track. They tie you to specific locations which is good for Incra jigs. Clamping your jigs in place gives you unlimited positioning choices not tied to these locations. This is the keep it simple method taught by Bob and Rick Rosendahl of the Router Workshop. To the best of my knowledge Bob was the first to design a miter sled specificaly for router table use and it guided off the fence.
