1 - 5 of 5 Posts
Discussion Starter #1
Hey guy, a few weeks ago somebody posted plans for a box jig. I can't seem to find it now. Anybody remember it & where to find it? I wish I'd saved it then.
I found plans just like Joseph's from Fine Woodworking on the net once and built one. It worked reasonably well. However, since then I bought an Ibox jig which is far more versatile. With the jig like I built you must have the same thickness dado stack each time you use it and with the Ibox jig you can put any size stack on and then set the jig to it. Of course if you are using a router instead the bit will stay relatively the same size so that won't be an issue.
By the way, before I took the home made jig apart I used it to make some dentil molding with it. If you look through my uploads you'll find it and the thread that went with the pics.
1 - 5 of 5 Posts
