1 - 9 of 9 Posts
· Registered
Theo
Reactions: Herb Stoops
· Registered
Theo
Discussion Starter · #4 ·
I'd have to lose a lot of weight to use that mirror or stand waaaay back. Yeah, that's not a look I want for a mirror.
I read that, and thought that if the mirror was a fair amount wider, it wouldn't be bad. Cost for the mirror would jump up tho, the guy said he paid $5. Thinking more, seem to me I ran across instructions for actually turning a piece of glass into a mirror. Think that would be considerably less expensive than buying a larger mirror. Not figuring on making one, but may try looking up the instructions.
· Premium Member
Retired since June 2000
I'm puzzled, at 1min 56sec he routes the inside edge, presumably full depth. How can this be done with a straight bit, it would just plough into the wood and it isn't possible to use a bearing bit!
· Registered
Theo
Discussion Starter · #6 ·
Did a bit of checking on how to make a mirror. Seems there are multiple ways. So I'll let you check out the one you like, if you decide to make a mirror.
[ url]https://www.google.com/search?source=hp&ei=noCBW57lIdDr-QaxrY7QBg&q=how+to+make+a+mirror&oq=how+to+make+a+mirror&gs_l=psy-ab.3..0l10.1219.4803.0.6324.20.7.0.0.0.0.1784.2356.5-1j8-1.2.0..2..0...1.1.64.psy-ab..18.2.2351...0i131k1.0.MjrsitHDnDs[/url]
· Registered
I think the way I would do it is to take a dado and on the table saw dado out the back the depth of the mirror, split the board down the middle and then make the rough edge cut, or rough cut down the middle of the dado. Connect the top and bottom and lay it on the mirror.
1 - 9 of 9 Posts
