1 - 7 of 7 Posts
Discussion Starter #1
Ok, got the table and (most of) the fence finished today. First time I've held a router (or even really a power tool) in 25 years. I relearned that the router has a mind of its own if you aren't paying close attention, and that I can't add and subtract fractions correctly anymore.
I took the top from an old drafting table that I wasn't using any more, and mounted it to a 3/4" block of plywood. Put a poplar skirt around it, with it extended on one side so I can attach it and use it as an outfeed table for the table saw. Legs are just plain old 2 bys.
Fence is split, so that I can also set it up to use it as a jointer. I still need to chamfer all my edges, put on some supports, and create the hole/box for the dust collection.
Anyway, here it is!
John
Table pre routing
Legs with bracing
Top outlined for cutting/routing
Jess em insert with Hitachi M12VC mounted.
Oops. This is what happens when you are confused on which way a dado cut goes and also not pay attention.
Full shot, without the fence.
Fence front
Fence rear
Discussion Starter #3
Yeah, the fence isn't completely finished yet. It does have T track mounted on the backs of the front pieces, so they can move in/out, and I plan on making the cutout and dust collection box next weekend.
Finally just about finished with the "building stuff so I can build stuff" phase of things.
John
Good job.
I'd fill the gap between the T-Track and the base (the little slip up) with epoxy.
That's cool I really like it.
I am just a bit ahead of u in my build , I decided to mount my table top on a cabinet. Iv got the draws left to make . Your top without the fence looks exactly the same as mine . I am looking forward to building something on my new toy .
What do plan to build on yours first ?
Cheers , si
Discussion Starter #6
Cheers , si
Slab and glass insert doors. That was the reason for building the table. I promised the wife if I got tools for x-mas I'd build stuff, so...
The current project is a TV bench unit with pier side towers and a bridge. The bench unit is almost done (Drawers and doors left), and then the side units. After that I have a whole raft of stuff planned.
John
Discussion Starter #7
Ah, I'm new I can't edit.
Along with the dust box and braces, I've got more T-track that I'll eventually mount in the face of the fence for jigs and attachments.
John
1 - 7 of 7 Posts
