Made my own table, and the router plates. The plates are 1/2" plywood, and just sit in place, router holds them down. No play, no shimming.
I tried to use those snuggers but they didn’t snug, so just made holes to secure my Jessem to the Bosch table.If the plate and hole are not close fit then usually there is a way to make it somewhat better. On my Jess Em lift the plate has an adjustable slider for both X and Y that you simply loosen to move and then tighten back snugly. This doesn't lock the plate in place but keeps sideways motions from happening. The weight of the lift and router keep the plate in the table base. I think this is what you're asking about. I don't see where the base plate vs the lift plate should be any different less the lift. Any yes, many plate have holes for screws but even the makers will tell you that they don't recommend using them as it isn't needed.
See here and here on my webpage and you'll see the corner holes (not used) and an adjustable slider. This image shows the wood rings I made for a tighter fit keeping in mind that my lift plate would not need to be lifted from the table to change bits. Hope this helps.
BTW, welcome to the forum.
Welcome to the forum Joel . I have nothing to add , as these guys got you covered .I just legally changed my name from N/A to Joel.
That’s incredible. You literally have a flux capacitor in your ride.Welcome to the forum Joel . I have nothing to add , as these guys got you covered .
But I thought I’d show you something in my 78 TransAm that you could relate to .
I’m heading back to 70’s as soon as I can figure out how to generate the 1.21 gigawatts needed to fire it back up again , as 2020 isn’t working out so well lol
I’ll look you up lolThat’s incredible. You literally have a flux capacitor in your ride.
If you ever figure out how to generate 1.21 GW—Please take me with you.
“2020—Officially the longest year on record”
