Certainly could, if I were inclined to put the time into gluing all those pieces together and had a reason other than 'I told you I could'. :grin:
David
Edit - this took all of 5 minutes to draw in Fusion 360 though I didn't bother with the appearance to create all the little pieces nor did I go to the CAM portion to generate the toolpath. I would cut halfway, flip the piece, then cut the other half. This is 14" diameter but I could go up to about 24" if I wanted. Is there a market? :wink:
David
