I am having trouble cutting a double bead on the edge of a drawer divider with a single bead cutter. The first cut is fine but when I try the other edge the bead is slightly smaller and the end of the bead got gouged. I am using a 1/8 inch radius bit in a router table with a fence. It seems like the edge width after cutting the first bead is no longer uniform and the edge does not register correctly against the fence. Is this something that cant be accurately done with a single cutter bit or is something wrong with my technique?
Woody Dixon
Woody Dixon
