Can anyone recommend a high quality double-sided tape for pattern routing and …?
I use the cloth backed type-more expensive but holds better.Use smaller pieces and its easier to remove. Also squeeze it together with clamps makes a tighter bondCan anyone recommend a high quality double-sided tape for pattern routing and …?
Old post but a great tip, BJ.. unless I'm the only one who's fought to get the double-stick tape off of a template. <g>Here's a a tip, If you put down clear tape (packing tape on the pattern/blank stock) b/4 you put double side (2" wide carpet tape) on it will come off easy and clean.
Bj![]()
