it is the easest one to use 1 set up and you cut both tail and pin you just turn the jig around on the router table i use 2 routers and 2 tables one for each bit you just switch tables to the other and i can cut both in the time you do with switching the board and setting it up of course with 1 table you switch bit's just depend's on how much you do some are better or easer to use lot's of ways to cut dovetail's del schislervrbradley said:thanks del, appreciate the input, i think making a dovetail on the router table makes so much more sense than the "fussy" jigs and using a hand held router
